Zum Hauptinhalt wechseln
LTE-Version des iPad Mini 3. Es wurde am 16. Oktober 2014 angekündigt und ist der Nachfolger des iPad mini 2.
Why is this device ghost touching after replacing the screen?
I replaced this iPad Mini 3 with a new screen from iFixit and the customer brought it back saying that it was doing things on it's own without her even touching it. I confirmed that is the case and it seems to be happening when a slight bit of pressure is applied to the lower left or right corners. I took a video if you would like to see it happen. I opened it up again and nothing looks pinched and I put some EMI tape over the home button cable, since I read that may help. ANy ideas here? I also ordered a new screen in case I have to go that route.
Thanks in advance!
Bodhi
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Have you confirmed that the cable for the digitizer is seated correctly?
Also, I have heard that a power cycle may also fix the problem sometimes.
War diese Antwort hilfreich?
Bewertung 0
I have the same problem with an iPad 3 4G... Even when the digitizer isn't touching the frame the iPad goes crazy. I've tried different digitizers from different companies but still having problems. I know the solutions for the iPad mini 1 and iPad air but with this one i'm stuck... Anyone?
Bewertung 0
I too just posted this similar question on fixit and i'm in the same boat and no one seems to have a fix for this. We order our parts from china and are the same that many companies sell here in the states. I have contacted my supplier about this issue he stated I should try OEM original apple screen for the iPad mini 3. So on my next order I'll be ordering some. I'll report my outcome.
Bewertung 0
1 Kommentar:
I think it's just bad quality batches of digitizer glass touch screen. I've been repairing many iPad Mini 3's without issue using Kapton tape as a safe measure.
von
Antwort hinzufügen
Mac Daddy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 489
