Zum Hauptinhalt wechseln
Modelle A1237 oder A1304 / 1,6, 1,8, 1,86, oder 2,13 GHz Core 2 Duo Prozessor
312 Fragen Alle anzeigen
What are the possible causes of an overheating CPU and MCP
Hello
After connecting a defective LCD cable on two macbooks A1304 I had no image and the CPU overheats enormously
This cable has probably short circuited a few items ...
After observing the two motherboards I noticed a transistor HS on both the Q9807 serving fueled the backlight
So I replaced these two cards but the problem is always the same :
-No Screen image
-No Startup chime
-The CPU and MCP overheating enormously
As I am not an expert in this field I prefer requested
What are the possible causes of an overheating CPU and MCP after a short circuit ????
thank you in advance for your assistance
Mother board model : 820-2375
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hello,
Tried to make the SMC reset.
https://support.apple.com/en-us/HT201295
War diese Antwort hilfreich?
Bewertung 1
Did you check you fan speeds? Maybe that it destroyed the fan controller on the motherboard
Bewertung 0
Antwort hinzufügen
David G wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 154
