Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
Force touch doesn work correct after screen replace
Hallo.
First i want to apologize for my english.
So I replace lcd and touch screen (also with 3D touch). LCD and touch ID works perfectly but 3D touch doesn´t works correctly, specially on sides of the screen. Does some one similar problem?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 9
8 Kommentare
Was it an ifixit screen replacement?
von
I havent done one yet, but it could definitley be a faulty screen, you dont happen to have another one to test do you?
von
It can be a faulty lcd or a bad conection with the motherboard
try to clean the conection and try again if not replace screen.
von
Replaced screen twice, even with 3dtouch set to "firm" a slight touch to the screen tries to bring up 3D Touch. Especially frustrating when typing.
von
Thanks for your answers and tips. Problem was in IC on screen flex. IC was not programed.
von
3 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
10 Antworten
Gewählte Lösung
It may just be due to a bad screen or a poor quality screen. Try getting it fixed by apple its only about $129.00 USD
War diese Antwort hilfreich?
Bewertung 4
5 Kommentare:
Seriously, you should not have even touched your phone. Apple does it for cheap compared to buying the part yourself etc.
von
Ithought so too, but i wanted other opinion too, thanks
von
will apple touch fix it if the screen has been replaced?
von
Shelly, Apple will check for all original parts since opening your phone voids all warranty. If you can you have to switch to the original one and they might not notice it has been touched.
von
so did it resolve? n if it did whats the process? im having the same sensitivity defect on 6s! like a light touch activates the 3d touch! help me on this!
von
Not all the replacement screens in the aftermarket have good performance on 3d touch. Check this test:
Diese Einbettung scheint ungültig. Bitte prüfe die URL.
Bewertung 2
Had the same problem, we changed our first 6s screen (a phone we bought cheap with a broken screen) we bought some 3rd party screens with the lcd attached and the 3d touch would work on the left side of the screen but not the right. We bought this phone just to try.. conclusion.. don't buy 3rd party screens.. take it to apple.. Not until the distributors can master the 3D touch at least.
Bewertung 1
Hi Guys update I've replaced a few 6S screens and it didn't work so being the perfectionist I think I am lol I went all out and tested it many time still noting finally I made sure the screen was really snug and put sticky tape on top and bottom of screen and Viola 3D Touch started working .. This worked for me hope this of some help to any others with the same issue
Bewertung 1
I also had this problem , was advised by the seller to make sure that the backlight was fully covered by metal LCD plate (Although what this would have to do with Force Touch I have no idea)
Ended up getting the entire phone replaced ......... but will be following this post with interest!
Update (02/29/2016)
Ok for everyone following this thread here's an update. I received an email today from one of my suppliers saying the following:-
"iPhone 6S 3D active touch function issue is solved successfully by our factory.Our iPhone 6S screens are with sensitive and perfect 3D active touch function."
iPhone 6s 4.7 inch screens with nice 3D active touch function:
Unit price: $118.1 for AAA made by original lcd, original back light, original flex cables.
iPhone 6s plus 5.5 inch screens with nice 3D active touch function: Unit price: $175.5 for AAA made by original lcd, original back light, original flex cables.
So it looks as though 3rd partys have figured out how to keep 3D Touch / Force Touch working properly now! They said initially with the 6S that the 3D touch was causing big problems but their engineers fixed it.
I guessed (possibly incorrectly) that posting the supplier contact information here wouldn't be allowed for some reason? If that's wrong please let me know!
Bewertung 0
4 Kommentare:
Alex, I just changed my first 6s screen and didnt even think about the force touch. Well its not working. is there something i can try? How did you get the phone replaced?
von
Hi Shelly,
I unfortunately never determined what caused the force touch problems .... Ie whether it was an error on my part during the repair or an actual fault with the screen I ordered but yes Apple did replace it. The phone was only 2 weeks old and the replacement screen had the Apple logo on every cable so it must have been a full OEM original part that I ordered (it was expensive!)
von
Did you order the screen from ifixit?
von
No the screen didn't come from Ifixit. I think like most screens out there you just have to make sure that you get a decent quality replacement screen.
von
There is so much that has got to be taken into consideration now with the 6s LCD.
On the iPhone 6/5 etc you can have any grade of OCA (different widths etc) and it wouldn't really matter. Glass thickness could be different but it wouldn't matter. Now 3D touch is here everything needs to be perfect. The glass/oca/polarizer all need to be 1:1 original to maintain 3D Touch.
My opinion is don't ever use a 3rd party LCD on an iPhone 6s.
Bewertung 0
For everyone who says to bring it to Apple store to replace the screen, apparently you haven't tried this yourself. Latest is that Apple tells everyone their phone is bent or damaged in some way (even though it is not). They say because it is bent they will not replace the screen and that you need to buy a new phone.
Which is why all these other companies are charging more than Apple store, because they know that the Apple store will not replace the screens on your phone anymore.
Bewertung 0
Touch ID won't work after screen replacements tho .. 3D/Force touch works .. Any suggestion ??
Bewertung 0
1 Kommentar:
If you replaced the home button as well Touch ID will not work because the fingerprint sensors are serialized. Replace home button with the original one and it should be OK. Otherwise you may have damaged the ribbon cable. Try reseating the cable if that didn't happen.
von
http://bbcpak.com/2016/10/fix-3d-touch-i...
Here i found a usefull article Iphone 6 and 6s
Apple’s iPhone 6s and iPhone 6s Plus are the company’s most successful iPhone launch, with over 13 million sold in its first weekend of sales.
Bewertung 0
I know the solution you all wrong and missleading poor people ,
The solution: when you replace the screen , make sure that the battery have to be perfectly leveld , you can see that the stick that hold the battery its not only for stickin it in place , its also for levelin the battery in perfect height with the screen , if you have even tiny gap betwen the battery and the screen , the 3d wont work for some parts of the screen , try to level the battery with something ot just buy original white stick strip and place it from scratch ,
Thank you please notice me if it helped you -uri kaspi
Bewertung 0
Antwort hinzufügen
Pavel Svejcar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 26
Insgesamt: 65,670
