Zum Hauptinhalt wechseln
Der 1999er Chevrolet Malibu ist Teil der fünften Generation (1997-2003), die von General Motors hergestellt wurde. Dies ist der erste kompaktere Malibu mit Vorderradantrieb, den General Motors wieder auf den Markt brachte, nachdem die Malibu-Reihe Anfang der 1980er Jahre vorübergehend eingestellt worden war.
Overheating and question about the transmission fluid pan
1998 Chevrolet Malibu LS 3.1L
I'm having trouble with my 98 malibu overheating sometimes it will then sometimes it will stay At 3/4 on the gauge I've already replaced the thermostat and also have a question about the transmission fluid being able to check it and how to tell if it's low or needs changed
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
Where is the transmission refill located?
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Lee, since TJ. is offering to take care of your transmission question, I will take a stab at your overheat condition. There may be air in the system, which will have to be bled out, so system can function properly.
Check the attached links,instruction and guides on more reason for engine to overheat, Good luck.
https://www.youtube.com/watch?v=ad9u8jAD...
http://www.auto-repair-help.com/auto_dia...
War diese Antwort hilfreich?
Bewertung 3
I need too check on somethings first, I do believe that they did away with the transmission dip stick in that year. The dealerships have the dipstick as a tool. I made one so that the guys the install the transmission can use it. We have a trick for doing it without it. I need too know if you can pop the hood and look down at the top of the transmission and see if there is a yellow cap you can unscrew? I will get my computer out tomorrow and pull up the information for you. But check that for me if you can.
Thanks, TJ
Bewertung 1
1 Kommentar:
I have a 3.1 malibu 1997. do these have a dipstick at all for the tranny fluid?
von
A possible gasket head problem, white smoke,little water from exhaust pipe, its seem oil and water mixs
Bewertung 0
You can check the level through the overflow tank shown on the check fluids page. Careful if the engine is hot? Best wait until it is cool. Leave the hood up to cool faster. Later try removing the cap but SLOWLY and if there are no steam coming out.
The overheat problem I had was related to a coolant temp sensor, on the 3.1 it is on the driver's side. Under the throttle body control. Replaced it and the fans don't run until the engine is hot.
When the engine now heats up on mine, the car still overheats and because the engine is hot and the radiator is cool gives a clue. If there has been coolant loss and a refill, it might be due to air in the coolant lines, and so don't be so quick to guess it is the thermostat. On the 3.1 they are a b....h to change. But hope that give you ideas. Also google for the replacement of such on google u tube and watch the movies. That is good. OK? Hope this helps.
Bewertung 0
Antwort hinzufügen
Lee wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 34
Insgesamt: 1,008
