Zum Hauptinhalt wechseln
Die Nintendo Wii Spielekonsole erschien Ende 2006 und wurde bis 2011 produziert.
Fix cracked wii remote front
I cracked the wii remote front infrared panel while bowling, now it doesn't point. Can this be fixed? All other functions are still working.
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
The tri-wing needed to open your remote is also available in iFixit's driver kits.
[verlinktes Produkt fehlt oder ist deaktiviert: IF145-022]
[verlinktes Produkt fehlt oder ist deaktiviert: IF145-028]
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
You can try just unscrewing the case and removing the front cover and see if that helps. The front cover is just a filter that only passes infrared light (and keeps dust out). But if you damaged the sensor inside, then you'll need a new Wii remote. To unscrew the case, I believe you need a tri-wing screwdriver, which you can get at Ebay. If the sensor is damaged, you can sell the remote to a hacker who only needs it for the accelerometer.
Bewertung 1
This is what I did to my remote and it works perfect http://howtofixstuff.blogspot.ca/2013/08...
Bewertung 0
The front of the wii remote had a cracked screen because my older sister or brother and me were playing just dance 1 2 3 or 4 she or he kept on hiting it out of my hand. XD is that your problem.
Bewertung 0
Follow a guide for your wii remote, but before that, make sure you buy a replacement case/screen.
Bewertung 0
Antwort hinzufügen
Val wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 37
Insgesamt: 6,598
