Zum Hauptinhalt wechseln
This device is the AmazonBasics 8-Sheet Strip-Cut Paper, CD, and Credit Card Shredder
How do I fix a paper jam?
My Amazonbasics paper shredder got jammed and no matter what I try, I can't seem to fix it.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Caution: Please do not place your fingers into the shredder in an attempt to fix the jam.
You can switch to "Reverse" mode on the shredder. This will back up the paper and loosen the jam. You may have to pull some papers out of the shredder in order to clear the blades. After the jam is cleared, you can return back to "Auto/On" mode and resume shredding.
Please refer to our trouble shooting guide. AmazonBasics B0050BPWBQ Troubleshooting
War diese Antwort hilfreich?
Bewertung 2
schredder is jammed tried reverse does not work. Red light on for overloaded. Thus unable to go forward or reverse.
Bewertung 0
1 Kommentar:
Antwort hinzufügen
Sam Fuller wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 3,960
