Zum Hauptinhalt wechseln
SSD upgrade temperature concern
Hi, I am investigating the possibility of upgrading to a SSD for this model. I had a temperature issue upgrading a Toshiba to a hybrid SSHD so I'm trying to be careful this time. I understand SSD generally runs cooler but just want to be on the safe side. Any tips like how to go about researching this would be appreciated.
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Hi,
The main difference between an (SS)HD and an SSD is that it doesn't have moving parts inside.
Because of that, SSD's will always be much cooler compared to an SSHD or HDD. But since the heat disposal and the cooling options of a notebook are limited, it will always be hotter than a traditional PC for example.
But I've done this kind of swap so many times with a lot of different types and brands of laptops, I can assure you; Under normal circumstances, heat won't be an issue
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Mark C wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 39
