Zum Hauptinhalt wechseln
Die Playstation 3 (im Volksmund auch PS3 genannt) ist das dritte Heimcomputer-Unterhaltungssystem der Firma Sony und der Nachfolger der PlayStation 2. Sie erschien am 11. November 2006
781 Fragen Alle anzeigen
How do I fix a PS3 that freezes shortly after power up?
I have a couple of Sony PS3s that will power on for a few minutes, start to play a movie, and then just freeze or lock up. They will usually not power up until they cool off. This seems like a cooling issue, but I have not worked on one of these before. I have heard that Sony had problems with the PS3s. Is there a fix for what appears to be an overheating problem? The fans are working and warm to hot air blows out. Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 17
3 Kommentare
Please help my ps3 games keep freezing every time I load a game in the ps3 it just freezes and make a loud noise and sometimes my ps3 games don't show up when I put the disc in the ps3, the ps3 makes a ejected sound but the game is still in the disc tray.
von
It starts with town and go from there
von
The eye that reads the disc is going bad or is already bad, you can buy a replacement on amazon for cheap and are very easy to replace yourself. My ps3 had the same issue buy a new eye replaced it and havent had any problems freezing.
von
Einen Kommentar hinzufügen
12 Antworten
Gewählte Lösung
I'm listing the iFixit teardown URL for you. I t should help you check out your PS3's cooling and guide you if it needs repair. Ralph
PlayStation 3 Teardown
War diese Antwort hilfreich?
Bewertung 5
1 Kommentar:
http://ba25ccg8misavz19vqjd7l2w69.hop.cl...
Follow this guide and u should be golden
von
Hilfreichste Antwort
If the thermal paste has come off between your CPU/GPU and heatsink, this will cause a problem. Also, if your fan is too dusty and can't spin, this could cause that problem. These are the first two things I would check. Note that I am currently in the process of making a full set of repair guides for the PS3.
Bewertung 10
just to make sure that it's a placing/heating problem: put it next to the room's window (or a bigger fan - and turn it on) if possible, and try to do what makes it usually freeze. if the extra cooling helps, you can be positive :)
what you can also do is use a hair dryer to get rid of the dust inside the ventillation system preventing the fans from blowing out enough hot air.
Bewertung 7
I had a problem with my PS3 40Gb overheating and going into turbo recently. Found it was pretty clogged up and that having it on its side rather than laying it flat helped significantly.
I also had a problem where I killed the power using the hard switch before I had turned the console off to standby (I know, don't ask) which caused it to freeze just like you describe. I found it was the HDD and it required a format of the drive (which lost me my saves, so back them up if you can) but fixed it straight away. The only thing I can think of is something got corrupted on the working space of the drive. Worth a shot if it's not just overheating.
Bewertung 3
1 Kommentar:
How do you go about this. And what's a hdd
von
I had the same problem and found this fix. Power on at the console but hold the button until you hear a second beep. "HDMI device has been detected" screen comes up. Continue through the prompts. I don't know why this works for me but resetting the output solves the freezing.
Bewertung 2
If it's heating up I would try moving it so there is as much open air around it as possible.
Some people like to "hide" their game systems so they usually get put in a cramped shelf which doesn't allow for ample cooling because the air in there can't escape so it heats up
Bewertung 1
1 Kommentar:
Lol...that'd be me and now my $@$* keeps freezing. I know what I gotta do now, thanks brother! Stay Safe
von
If you want to dissasemble it, try tightening the CPU Clamps, if they are uneven, they may cause the PS3 to overheat and freeze, this also applies to xbox 360's
Bewertung 1
Also if you have a intercool is it the problem? My nephew's PS3 had one, and it got clod and burn his PS3 out. Some of the video website have detail video on PS3 repair.
By the way
I have the following Site book marked it is a great help for PS3 owners
I was able find the parts I needed to repair my PS3 with this site,
I hope its a help to all of you also.
http://www.edepot.com/playstation3.html#...
Bewertung 1
1 Kommentar:
Thanks really helped with my son's PS3 that kept freezing
von
Freezing up just after playing a game is a precursor to the YLOD/RLOD and the cause is over heating. Too much dust blocking the air flow or the fan locking up, or the CPU/GPU not getting a good enough connection with the heat sink, or the solder joints have cracked and need to be reflowed. Your fix is with this link --> Yellow Light of Death Reparatur mit YLOD-Kit
Bewertung 1
1 Kommentar:
Tim Gelvin knows what he's talking about. I've attempted to repair many xboxes with the Red Ring. It could be over-heating, or something simple - but odds are, if it's an old PS3, there's either something wrong with the solder joints under the CPU/GPU, or something wrong on the BGA packages themselves.
Unless you know someone who can >PROPERLY< re-ball a CPU/GPU (i've done it improperly several times :P ), any DIY attempt will be temporary at best.
von
freezing issues are common with faulty hard drive
Bewertung 1
I had the same problem with mine, got to fix it changing the HD with bigger capacity, the original was out of use even for other devices. recurrent problem with some Sony PS3 series.
Bewertung 0
3 Kommentare:
My problem is every time I play a certain game it freezes but not with the other ones like it will freeze for a minute then unfreeze continually
von
Any suggestions
von
Mine freezes every time I just turn it on I don't know what to do I tried everything
von
For users who are streaming on the web browser, to get rid of PS3 freezing issue, updating is very much necessary because it will not only provide you better speed and accessibility but also it'll give you safety and security of your pieces of information.
Also check the link below for more troubleshooting methods
http://techstuffsarena.com/2019/08/23/pl...
Bewertung 0
1 Kommentar:
all these freezing issues is so basic replace your hard drive!!,
von
Antwort hinzufügen
Tinker wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 26
Letzte 30 Tage: 111
Insgesamt: 180,417
