Zum Hauptinhalt wechseln
Repair and disassembly guides for GE Microwave ovens.
349 Fragen Alle anzeigen
Why does Sensor panal malfunction
Panel resets all the time it comes up with close door and select food setting after unplugging unit from a.c. I can reset clock and get it to work once then the panal will revert back to close door and then ask to select food type 1-6. What needs to be done
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare:
edroberts43 you said that "after unplugging unit from a.c." does that mean you unplug it after using it? I am a bit confused by that. What model is your MW?
von
After the microwave malfunctions iIunplug the unit and I then plug it back in and am able to reset the panel my microwave is a G E s/n JVM172QP1WW
von
After you plug it back in then you get the error? Or do you get it after you set the time etc. and run it once? Have you consider that it is a faulty door switch?
von
Einen Kommentar hinzufügen
1 Antwort
Maybe falty power cord.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
@wesly how would a faulty power cord cause this error?
von
I don't understand how a faulty cord would make it not work or reset or nothing works
von
Antwort hinzufügen
edroberts43 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 1,108
