Zum Hauptinhalt wechseln
Released in February 2009, the AM3 socket is a CPU socket for AMD processors with 941 pin contacts.
Monitor not displaying anything because of CPU
My monitor is not displaying anything on screen. There is no fault in monitor, the fault is in the CPU processor, as I already checked my processor on other motherboard, my question is can i repair my processor. There is no damage as I can see on processor. It is clean.
AMD FX-8150.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
How do you know it isn't the GPU or video card? What's it in? What does it do? If the CPU works in another machine, it's obviously not the CPU giving the problem, is it? What does an external monitor show?
von
If your processor has no damage ,
if the possible solution is clean your RAM before connect on-board or replace
von
How do I fix my cpu on my computer
von
CPU's can NOT be repaired.
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
mohityenugwar there is nothing you can do. If your processor has failed the only way to get things working, is by replacing the processor.
War diese Antwort hilfreich?
Bewertung 7
There is no realistic way to repair a processor itself. The only viable solution is to replace it. You should be able to find used Phenom x2/3/4s fairly cheap online.
Update (01/17/2017)
Also, most AMD FX series processors do not include integrated video capabilities. These CPUs were designed for gaming systems with dedicated graphics cards. There is a possibility there is, in fact, nothing wrong with the processor.
Bewertung 1
1 Kommentar:
Re-read the question ". . . I already checked my processor on other motherboard. . . "
von
U can change d processor can't b repair
Bewertung 1
It could also be the motherboard. Try the CPU on a different motherboard and see whether you get anything. Vice versa, you could also try a different CPU on the same motherboard. My guess is that most of the time, it's the motherboard.
Bewertung 1
1 Kommentar:
von
Antwort hinzufügen
mohityenugwar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 27
Insgesamt: 3,450
