Zum Hauptinhalt wechseln
Das Mondo GDI-IRC6000, das 2011 von Grace Digital veröffentlicht wurde, bietet eine Lautsprecherplattform für Online-Radio-Streaming und die Wiedergabe digitaler Audiodaten.
How do I add a battery upgrade?
I purchased the rechargable battery upgrade for the Grace Digital Mondo. How do I install it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
There is a flat-head screw on the bottom of the device that attaches a large cover over a cavity in which the battery is held. Inside there should be a plug that you will attach to the battery.
Remember that plugging the Mondo into the wall will charge your battery, but leaving it plugged in will diminish the overall life of the battery.
Good luck!
von Teilen
thank you finally an answer! I probably could have figured it out but for the money charged how hard would it have been just to jot down on paper and include in box!
von Teilen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
After you add the extended battery upgrade, you may have problems with power. If this does happen, refer to our troubleshoot to identify any issues your having with your device.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Hi,
According to this link there are only 3 screws visible from the exterior of the product, and two of them are sunken so as to not be immediately obvious. Scroll down to Background and Identification.
Grace Digital Mondo
Presumably if you undo these the back may come off so as to allow insertion and connection of the battery.
This link may be of interest as it has mixed reviews about using the battery mode of operation.
http://www.amazon.com/Grace-Digital-ACC-...
Bewertung 2
Antwort hinzufügen
Nathaniel Brabham wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 24
Insgesamt: 1,325
