Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Service is "Searching" indefinitely
Work at a repair shop and have an issue with a customers phone showing that it is 'searching' for a signal on end. Is this something that a parts repair would solve or is it a mother board issue?
Update (03/12/2016)
It now says 'no service' despite there being service on the SIM
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Have you tried all the software things first? Toggling airplane mode, force restart, resetting cellular settings? If you've tried all those things and it still doesn't work, you can try disconnecting then reconnecting the battery, then connecting to wifi
iPhone 6 Akku tauschen
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Yeah, I did all those things. I also tried installing a new charging dock and antenna at the top but those didn't help. The phone isn't in my hands anymore but if anyone has another solution that would be great :)
von
Hilfreichste Antwort
If you have already tried the antenna fix, the Software fix, the charging port fix, housing swap, etc...keep reading...
Over the last year, I have had many of these come across my bench and the majority 8 of 10 (Guestimate) have been the Baseband IC. Dial *#06# you should see the IMEI, IF Not, then this just may work for you.
You will also want to look for Modem Firmware version in settings to see if it is listed, if not, then I would look at U_PMICRF Baseband power management IC.
also, if imei is there,modem firmware is there, it could be one of these 3: U_ASM_RF antenna switch module ic chip, WTR1625L Transceiver chip IC U_WTR_RF, or Receiver IC U_WFR_RF WFR1620
I suggest (If you have the experience and tools) that you remove the Logic board and the shield next to Sim Tray off. (The one closest to the battery connection, not near LCD Connectors).
Then you have a few options:
1. A temp fix that does work as a bandaid fix, reflow the baseband IC somewhere near 340C to 360C
2. Remove the baseband IC and reball it, also running short jumpers on the U1 and V1 pads (Not a permanent fix but much better than the reflow)
3. Same as number 2 but run long jumpers from the U1 and V1 pads. This requires removing the Sim Tray to get to one of the destination points and pretty difficult to reuse the tray as there is alot of plastic in it. the other jumper goes to the back side of the board.
Here is a video referred to me by @refectio of Chris long doing this repair:
https://youtu.be/1o49Ya-jEAA?t=3h55m00s
Bewertung 3
3 Kommentare:
It's weird but it seems to me that this answer used to have a whack of upvotes and every-time I link to it (and check), it seems to have less and less votes (or maybe I'm just imaging things or thinking of a different answer Michael provided). Can the mods see anything in the admin panel to see if there is any foul play?
@mayer @oldturkey03 @danj @jayeff
von
@refectio I just triple checked and this looks legit. I bookmarked it and keep a screenshot of it, just in case something else should pop up.
von
Thanks @oldturkey03 , perhaps I'm thinking of another answer.
von
Antwort hinzufügen
Paul wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 3,625
