Zum Hauptinhalt wechseln
Repair guides and support for phones manufactured by Jiayu.
8 Fragen Alle anzeigen
Phone dead after connecting wires to wrong pin on micro usb charger
I was in an emergency situation where i needed to charge my smartphone and i only have a broken usb wire and a mirco usb conncetor. I connected the positive and negitive wires to the pins on microusb connector. it worked fine for a few seconds but unluckily the positive wire slipped and connected to one of data pins. The phone turned off. Now as soon as i insert the battery the phone blinks every time i press power buttton and led light turns on or blink in 2 different colors.
I need to ask what parts could possibly be damaged or how can i check the damaged part as i cant sent it back to china to repair and prefer to order the damaged part instead.?
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@mtk there is not a particular part that will have failed. Any of the components along the dateline that got powered may have failed. Unless you disassemble your phone, have a schematic and a board layout, there really is no way to fix it.
War diese Antwort hilfreich?
Bewertung 3
if i change the power acpi or motherboard can it be useful in the same case
Bewertung 0
Antwort hinzufügen
Muhammad Tehseen Khalid wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 9
Insgesamt: 586
