Zum Hauptinhalt wechseln
Reparaturanleitungen und Informationen zur Demontage von Laptops und Notebooks aller Formen, Größen und Farben.
18857 Fragen Alle anzeigen
How difficult is it to replace the optical drive?
How difficult is it to replace the optical drive? I'd assume just replacing the entire Cd/DVD player unit. Is it pretty straight forward to the mechanically inclined person or are there some gnarly trade secret / Soldering resisters Geek-out situations?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
They just unplug and a screw or 2 removes them. But you'll probably have to take off the back cover to get into it.
Second option: get a portable drive for those rare occasions that you need it. A perfect fit replacement drive might be expensive or unobtainable.
By the way, if your present drive is giving you errors or won't read at all, try carefully cleaning the dirt and crud off the lens.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thank you very much!
von
Hilfreichste Antwort
Hi @ryanousa,
Replacing ODD drives is fairly straightforward. Just 'Google' DVD or CD drive for you particular model laptop to find the replacement part. It is a complete unit, so all that is necessary is to remove the old and insert the new. If you are fortunate enough to own a Dell, Lenovo or HP/Compacq laptop, you can "Google" search for 'your particular model service manual'. When you find it, you can download it and it details how to remove and install the ODD. If you don't have one of these makes just look for ODD removal of your model laptop on You Tube. You will usually find something relevant on there.
Bewertung 2
1 Kommentar:
von
Antwort hinzufügen
rynousa wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 66
