Zum Hauptinhalt wechseln
Model A1625. 2015 revision to Apple's set-top-box featuring an A8 processor and 2 GB of RAM.
30 Fragen Alle anzeigen
How to power Apple TV 4 in the car? 12v adapter?
Is there a 12v power supply solution for the Apple TV 4? I want to be able to run the apple tv from the 12v ignition supply from the car battery so that i can run videos to the car screen.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
5 Kommentare
How do you expect to stream from iTunes?
von
I don't need iTunes, my car has a built in wifi hotspot and I can tether from my phone or iPad for Internet. The new Apple TV has apps so it's more than just an iTunes Player
von
From my understanding AppleTV apps are still tethered to iTunes for them to run. So you'll still need access to the internet as you are driving.
von
Yes as I have said I have wifi hotspot built in... Now how about you try and answer the actual question Dan ?
von
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
You'll need a car DC to AC converter like this one: Tripp Lite PV150 Ultra 150 Watt Power Inverter so you can plug in the AC cord of the AppleTV into. We use these for our field staff to use their laptops in the field.
There is no 12volt power supply option for the AppleTV it was never designed to be a mobile device.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Yes I already have one of those adapters but I want something more neater hence asking for a 12v solution. I know someone has done it on the apple tv3 but wondering if a newer one has been released
von
http://carsystems.com.ua/universal-solut...
I just ordered this to install an Apple TV 4 in my camper. Did not receive it yet.
Bewertung 1
9 Kommentare:
Did you receive it yet?
von
Yes, I received it. It took quite a long time to travel, although it was posted next day. This seems to be due to customs. Nevertheless it arrived and is a really good solution. Even the 220V connector is replaced for a standard low voltage connector. It works like it should :-)
von
I philippemeyers did you order it from the Ukraine as I've sent them a skype to find out where i can get one
von
Did you hear back? Where did you order from?
von
I ordered one from http://carsystems.com.ua/universal-solut...
works perfect and the service was very good
von
4 weitere Kommentare anzeigen
Here is a US seller of the Apple TV4 PS: http://www.ebay.com/itm/122333123212
Bewertung 0
Here is another:
http://mct-corp.com/store/index.php?prod...
Bewertung 0
Is the way to do it without spending a nickel
https://m.youtube.com/watch?v=cao5UahhN6...
Bewertung 0
Antwort hinzufügen
Deleted193439577 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 42
Letzte 30 Tage: 177
Insgesamt: 34,882
