Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
My screen wont let me swipe, what should I do?
When I push my home button it lights up but when I try to swipe to get to the password screen it wouldn't move it. And I tried to do a hard shutdown and sometimes it works and sometimes it doesn't. When it does work it, it lets me get into my phone and then it wont let me move or get into somethings.
Please help!!!!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Did this happen following a repair, a hard (or not so hard) drop, liquid spill? Any incident?
In any case, there are 2 possibilities I can think about until you tell us more about the history of this device. If your device is out of warranty, here's what you can troubleshoot:
- Screen gone bad. Trying on a known good screen will confirm or rule out this possibility. Here's a guide that shows you how to try on another screen. It needn't be new, it can even be cracked, but it just needs to be known good. Alternatively test your screen on a different known good device.
- If a known good screen doesn't solve it, the touch circuit (and most probably a touch IC) has failed. In that case it stops being a DIY repair and should be taken or sent to a reputed repair store (it's a totally doable repair but at the same time easy to botch if the technician is not experienced enough) that can do micro soldering repairs or that subcontracts them to micro soldering experts.
If failed touch circuit does indeed turn out to be your issue, you can also have it replaced out-of-warranty at an Apple Store (provided it was never repaired by someone other than Apple before); but you'll loose your data in case you don't have a current iCloud or iTunes back-up. It's also your most expensive option, though guaranteed to get you back a working device.
War diese Antwort hilfreich?
Bewertung 3
If it's not a software issue then it is clearly related to a faulty digitizer or its connector.
You can first try unplugging and cleaning the digitizer connector and see if the problem still persists. If so, I'm afraid you will need a new digitizer.
Bewertung 0
Antwort hinzufügen
Grace wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 51
Insgesamt: 9,304
