Why does the audio on my drum set sound distorted?
Whenever my child hits anything on the drum set the audio sounds weak and garbled.
Ist dies eine gute Frage?
Hey Zuhair!
There could be a few reasons why the audio on your drum set has become distorted. The first thing I would suggest would be to adjust the volume switch on the back of the drum set to a different setting. If that doesn’t work, then I would suggest trying change out your batteries. You would be surprised how many issues a fresh set of batteries can solve. If you’re still having problems after that, then you will most likely have to replace your speaker or volume switch. These steps are a little more involved, and will require the use of a soldering station. If you’re feeling adventurous, you can view step by step instructions for this process in the Vtech Kidibeats Drum Set Troubleshooting Guide.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 588
