Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Wifi Greyed Out and Repair Steps Completed
I've completed the following steps to no avail for my iPhone 6 Greyed out wifi:
1. Updated version to latest
2. Restarted phone
2. Reset wifi network
3. Restored to factory settings
4. Replaced wifi antenna
None of this worked. I don't want to pay Apple for repair or a new phone. Do you think replacing the motherboard might work? That is a heck of a lot cheaper than the options Apple has to offer.
Everything works fine on the phone except wifi and Bluetooth. Thank you for your time.
Respectfully,
Mike
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Do not replace the MLB, it's a waste of money. Try to repair the MLB instead.
War diese Antwort hilfreich?
Bewertung 2
My WiFi was greyed out and my Bluetooth was also not working on my iPhone 6 so I replaced the WiFi antenna flex cable and then my WiFi and Bluetooth both started working.
This seems to be a pretty common problem but nearly all of the youtube videos and websites are rubbish.
iPhone 6 Antennenflexkabel tauschen
Bewertung 2
It's the wifi chip, common problem but not so much an easy fix, it requires soldering skills time and effort, best bet is YouTube iPhone 6 wifi chip replacement and that'll tell you where the chip is on the board,
Hope this helped
Regards
Lucas
Bewertung 0
1 Kommentar:
There's maybe a different thing you could do but it's strange and probably not advised, heat your phone up with a blow dryer until the temperature warning comes up the put it in the freezer for like 2 mins I've heared it's helped but definitely would not recommend !
von
So when your wifi is greyed out its an issue with your wifi/bluetooth module or usually surrounding small components (possible capacitor not at right temperature).
Heating the wifi module isn't something I'd recommend as these wifi modules hate heat.
Was the phone liquid damaged or exposed to extreme heat?
Bewertung 0
Antwort hinzufügen
Michael Sims wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 2,274
