Front seat belt relay switch
How to replace front seat seatbelt relay switch on a W123 Mercedes 300D
Ist dies eine gute Frage?
Vom Mercedes Typ W123 gab es verschiedene Modelle wie 240D, 300D, 300TD, 280E und mehr. Es handelt sich um Limousinen, Coupés und Kombifahrzeuge aus den Jahren 1977 bis 1985.
Rep: 1
Hi Ken,
If you mean the relay that turns on/off the seatbelt warning light, and also the buzzer, it is located up under the kick panel beneath the steering wheel aka on the driver's side.
Use this guide to remove the kick panel on that side:
Mercedes W123 untere Zierblende ausbauen
Then look for a silver box about the size of a pack of cigarettes, mounted almost all the way to the left near the driver's side door. This is the seatbelt relay. Note that there is another silver box, that is thinner but taller/wider, which is tucked up a bit further back in the dash. This is the cruise control box.
Once you've located the seatbelt relay, it's just a matter of unscrewing it and unplugging it and the reversing that to install the replacement part.
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 8
Insgesamt: 346
