Why the green light is permanent?
Hi, my Bose SoundDock Portable v2 has the green light permanent, and a i can´t use it. I can´t turn up the volume or turn down, and don´t reproduces the music.
Ist dies eine gute Frage?
Is this with both the buttons on the device and the remote?
War diese Antwort hilfreich?
No, when i press the buttons on the device or the remote, my bose doesn't make anything, the green light stay permanent
I'm certain you've tried unplugging it and waiting a while before you use it again. Also I'm wondering if it works while its plugged in. It could be a faulty battery, for which you could Bose SoundDock Portable v2 Battery Replacement replace the battery
i have the same problem with my bose soundock series ii, the bose sevice center told me that it need to replace the sound processor module but very expensive so i try to repair it myself, i found out that the crystal oscillator 16.974mhz is not working properly, tried to replace it but no luck, so i solder a 22pf capacitor to one pin of crystal to ground, now its working.
Hey Marvin, you didn;t happen to take a photo of your completed fix? Thanks,
Hello Marvin can you please attached the photos so it will be easy to fix the issue mine have same problem please help
This is the fix you need
22pf ceramic capacitor
Thank you, worked like a charm
hello do you have to regulate your problem??
Hello all. My SoundDock Series II does the same thing. For a while the green LED would stay lit after a power outage, but would be fixed by replugging the power cable on back of unit -- now that method doesn't work. I suspect there is an issue with the power supply, or with the power stable circuit. I will pursue this problem and post any conclusions.
Would like to know what the fix is for this issue when it's available, would like my SoundDock working again.
Thanks.
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 87
Insgesamt: 5,970
