Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
591 Fragen Alle anzeigen
MBP will not power on or respond to pressing the power button.
I need some support advice for my 2011 Macbook Pro. I used it early Saturday morning. I left for the day leaving it on hibernate and unplugged. Bad habit I know, but I've done it a million times. When I arrived home the computer was completely off. The battery indicator says there is a charge. However, when I press the power button there is no response. No chiming....no clicking. I purchased a new hard drive a few months back. So I swapped the hard drive back to the original hard drive. No response. I tried resetting the SMC with no response. There's been no water damage to the machine. I'm using the original power cord so I know that's good. When I plug it in it's still charging the battery according to the indicator lights. (The battery wasn't full.) Does anyone have any suggestions?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Unplug the keyboard and battery, plug the charger in and see if it turns on. This model should boot if the charger is plugged in.
Let me know how this goes.
War diese Antwort hilfreich?
Bewertung 2
you should leave it plugged in because it happened once, i plugged in, and then it will wake up.
Bewertung 0
2 Kommentare:
It's not asleep. There is no response at all from the computer at all. It's not a matter of the battery being dead and just needing a recharge. According to all indicator lights the battery is fine.
von
have you checked all the wiring inside the laptop?
von
Antwort hinzufügen
christybondurant wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 537
