Zum Hauptinhalt wechseln
AC-Netzadapter für MacBook, MacBookPro und MacBook Air. Ausgestattet mit einem magnetischen Stecker, der sich von selbst trennt, wenn daran gezogen wird. Die MagSafe Netzteile der ersten Generation (2006-2012) haben einen etwas dickeren L-förmigen Stecker. Erhältlich in 45 W, 60 W und 85 W.
Is it normal to have white paste inside charger or something leaked?
I decided to replace a cable in my MacBook charger (old MagSafe). I cracked it open and there is a large blob of some sort of white rubberish paste filling a good portion of the space inside:
I am not sure whether it is a special filling paste or something (capacitor?) leaked. I was not able to find any obvious sorts of leakage.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The white rubbery stuff is indeed a filler, I think it may help conduct heat towards the shell so as to avoid the formation of hot spots in the circuitry. It also helps to keep the components in place, which is a good thing because power bricks are relatively prone to rough handling.
Of course, it also makes the power brick more difficult to repair, but then, power bricks as a rule should be replaced, not repaired. Repair of power bricks by non-experts in particular are not unlikely to present a significant safety hazard.
War diese Antwort hilfreich?
Bewertung 5
3 Kommentare:
I just replaced the cable by unsoldering the old one and soldering new one. I would barely call it a repair. The place where wires were soldered was not covered by the filler, so it was not hard at all.
von
There's always the exception that confirms the rule ;)
However, one should keep in mind that a carelessly executed repair might compromise the galvanic separation between input (mains!) and output (the equipment being powered, and by extension, your body).
von
Thanks I will keep it in mind.
von
Antwort hinzufügen
Andrey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 33
Letzte 30 Tage: 107
Insgesamt: 6,830
