Zum Hauptinhalt wechseln
Manufactured by Porter-Cable, the PC60TAG is an easy to handle miniature version of their commercial angle grinders for quick, light duty grinding tasks.
5 Fragen Alle anzeigen
Why is my grinder overheating?
Recently when i use my grinder, it begins to get very hot after a short period of use. This does not seem normal, could you offer any suggestions to remedy this?
Ist dies eine gute Frage?
Bewertung 2
5 Kommentare
student question
von
some time field coil burn angle grander
wht is the reason
von
My grinder burned, what's the reason
von
hello sir i have 9" angle grander . in working time smoke com inside the body . when i open the grander . armachor is burn . why armachor burn what is the reason
von
armachor burning reason also carbon brush is crack
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hey Mackenzie, this is what iFixit suggests you to do if your grinder is overheating:
Grinder getting unusually hot while in use
When the grinder becomes hot and can’t be handled properly.
Use of grinder for long periods of time
While the grinder is in use a certain amount heat will be produced although if the grinder becomes too hot that it unpleasant to handle, you must stop shut off the grinder and allow it to cool off for some time and recheck to see if it has cooled off completely before reuse.
Build up of debris and rust
When an excessive amount of debris and rust build up, it can cause the grinder wheel to be clogged and overheat. In order to solve this issue you can refer to the Accumulation of Debris above section (I copy-pasted the section below).
From use debris can be cause of low resolution when air particles get inside of the grinder. In order to resolve this issue you will have to clean the moving components of the grinder and add a little lubrication oil to keep it moving.
-More troubleshooting fixes can be found here
-Let me know if this helps.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
cleaning the grinding so more hot
von
machine inside cleaning so many more time heat continuances
Bewertung 0
Antwort hinzufügen
Mackenzie Fairbanks wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 13,731
