Zum Hauptinhalt wechseln
Das Samsung Galaxy S3 ist ein Smartphone mit Multitouch- und Drahtlosladefunktion, ist Eyetracking-fähig und hat einen vergrößerten Speicher.
459 Fragen Alle anzeigen
Trouble turning on, but will turn on eventually.
So I have an old S3 that I don't use any more because it was !#^&^$^ me off. I figured I'd practice some phone repairs on it.
Anyways, the phone won't boot up most of the time. I will push the power button and the samsung logo will pop up and then nothing. I take out the battery and keep trying until it finally boots up. also if I smack it against my palm it helps get it to boot. Is there a loose chip? bad power button? Is it a known issue? Let me know and thanks for your time.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
There are multiple causes for this:
- Bad battery.
- System Software is corrupt. Probably not in your case as you can get it to boot.
- Nand flash memory chip on logic board has gone loose.
Have seen the issue on a few Samsung Galaxy S3's but I will say it isn't a common issue.
Have you tried cleaning the charger port with a toothpick or something equivilant? It may help.
von
Have not tried cleaning the charge port, I don't think it's a bad battery.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Bad power button. New one has to be micro-soldered on.
After Samsung logo comes on the power button circuit is stuck closed telling the device to turn off.
You can take motherboard out of device and check continuity with a multi-meter. Put leads on contacts located on the back of button and get a person to push the button. Be careful not to put the leads on the wrong place-gives a false reading. If the meter beeps (when button is depressed) and then stops when the button is released then the button is good. You need to do this a number of times because sometimes it is a intermittent problem.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Bryon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 81
