Zum Hauptinhalt wechseln
Seit 2006 fertigt Kirchen Aid dieses Rührgerät mit 10 Geschwindigkeitsstufen.
KitchenAid Professional 600 mixer not turning on?
Every time I try to turn on my KitchenAid mixer nothing happens. I've tried unplugging and plugging it back in but nothing happens. I even checked to see if it was a faulty outlet but the outlet works fine. Help!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The wiring of the outlet plug may be faulty and in need of replacement check out our trouble shooting page for help! KitchenAid Professional 600 Troubleshooting
War diese Antwort hilfreich?
Bewertung 2
One easy thing we see a lot is the mixer has to be in the off position when it is plugged in, or it will not turn on. It's silly but you would be shocked how often we see this. So, turn the mixer off, unplug it and plug it back in and see if it makes a difference.
If not, you are most likely looking at a bad speed control board, though you could need a new cord or motor 95 % of the time it would be a bad control board.
You can find the service manual and parts online at kitchenaidexperts.com
Bewertung 0
Antwort hinzufügen
Luke wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 96
Insgesamt: 8,278
