Zum Hauptinhalt wechseln
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Fragen Alle anzeigen
Intel iMac as an external monitor - Guide
I had a 2006 Intel iMac that died (logic board / graphics card failure) and instead of consigning it to the bin, I aimed to turn it both an external monitor for my screen-less 2009 MacBook Pro (LCD driver failure, failing battery) and any HDMI device I wanted. I had seen this done with G5 iMacs, but never with Intel ones, which use different display types, so decided to have a go and was successful!
My guide can be found in the answer...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Guide of how I did it - http://www.instructables.com/id/Intel-IM...
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
@moomike - Michael - Sadly all of your work here won't be found if you just post it here. The best thing to do is create a IFIXIT guide that way someone who also wants to do the same thing can find your efforts. Follow this link: Create an IFIXIT Guide
von
Antwort hinzufügen
Michael wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 226
