Zum Hauptinhalt wechseln
Reparaturanleitungen und Informationen zur Demontage von Laptops und Notebooks aller Formen, Größen und Farben.
18865 Fragen Alle anzeigen
My Dell laptop E6410 will not turn on
I got my laptop a bit wet today from the rain and when I brought it home nothing turned on. No fan, no hard drive, nothing at all. I tried the "take out battery and adapter and hold the power button for 30 secs" but that only made the power LED light come on and still nothing else. The battery light flashes orange sometimes then goes away when the battery is in and the power light stays on. When I first put the battery in the light was kinda white, then light purple and then it went to solid orange to flashing orange. Thank you all so much for the help.
P.S. When I put everything in and the power light does come on, the power button is useless and will not turn off the laptop
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Pull out the battery,open the laptop don't try to dry it out tear the laptop down to the motherboard and look for burn spots clean the board in an ultra sonic cleaner with a distilled water and cleaning solution. if this is unavailable clean with a soft cloth and IS alcohol of at least 95 % clean the connections and clean the contact points of the battery. the sooner you do this the better chance you have of saving the computer. Drying out the computer only promotes corrosion which is the worst thing that can happen
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
I totally agree Jimfixer, But I was not going to suggest taking the motherboard out of this one. Have you seen the tear down? To be honest, the right answer would be..Is to take it to a shop.
von
Your next step would be... is to take out the battery, then place a towel of some sort between the Keyboard and Display, close it up and let it sit upside down for about a week, then try to turn it on. It will take about that long for the water to evaporate. The thing is, you tried to turn it on right away while it was presumably wet that MIGHT have shorted something already.
Bewertung 0
2 Kommentare:
Do you think a battery replacement will fix it? And is the hard drive at least saved and I can put it in another computer?
von
It depends on where the rain water went. I would wait for it to dry like stated above to avoid further damage, Then see if it will turn on with the battery removed and the power supply plugged in.
von
Antwort hinzufügen
tagbeatz0 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 1,199
