Zum Hauptinhalt wechseln
Reparaturanleitungen für Computer, die über kein integriertes Display verfügen und für den stationären Gebrauch gedacht sind.
2134 Fragen Alle anzeigen
second screen vga to dvi-d
i got some vga screens at home wich i dont use and i want to use one as a second screen but is it possible if i get a vga to dvi-d adapter to use that as a second screen??
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
You cant turn an analog signal into a digital signal. You can only turn a digital signal into an analog signal.
So, dvi d to vga, but not vga to dvi. Do you have a video card in this desktop? If you do, you should have two outputs. Usually 1 for VGA and 1 for dvi. In that case you would plug one monitor to vga and then get a dvi d to vga adapter and connect the other.
I hope this helps.
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
Here's what you'll need, a male dvi to male vga cable: http://www.newegg.com/Product/Product.as...
Bewertung 2
Don't you mean a DVI to VGA adapter perhaps?
Now from what i know is that graphics cards came included with such an adapter, even the more recent ones like the R9 390X.
So yes, you could hook up a VGA display with such an adapter.
Bewertung 1
1 Kommentar:
i want to use my dvi port for 2nd screen so dvi to vga
von
Antwort hinzufügen
pascal molenberg wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 128
