Why dose my printer keep turning off?
I keep trying to use my printer but it keeps turning off shortly after I plug in the power I already friend replacing the power module and it still keeps doing it
Ist dies eine gute Frage?
Grabiel
Its possible that the auto off feature may have been activated.
What this does is shut down the printer after a set period of inactivity this is done mainly to save electricity.
If you go into the setting menu on the printer look for either power settings or it may just have its own page on the menu for Auto-Off and see if that's enabled.
If it is NOT enabled have you checked the usually suspects? maybe a lose power cord or even a faulty power strip if you are using one?
When it happens what do you have to do to get it to turn back on just hit the power button?
Hope this helps
Step one: Check to see if Schedule Off is enabled
Follow these steps to set up the Schedule On/Off feature, or to check the current settings.
1.On the control panel, touch the Right Arrow (), and then touch the Setup icon ().
2.Touch Schedule On/Off.
3.Touch Schedule Off.
•If Schedule Off is enabled and you want to turn it off, touch Disable.
War diese Antwort hilfreich?
My printer turns off just random and then sometimes turns back on but I have to sometime manually turn off then turn back on-does this mean I need a new printer
It’s difficult to say if you have disabled your printers power saving features and the printer is randomly powering off and on you have to power cycle the printer to get it to work it sounds like there may be something physically wrong with it.
It’s always a good idea to see if there are firmware updates available as they can often address issues like this barring that a replacement printer maybe be in your future.
Please be sure to properly dispose of your old printer should you buy a new one!
Good luck
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 35
Insgesamt: 5,544
my printer always printerfailure 0x610000f6,may iknow what is the problem
von motto_perlada
