Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Circuit board water damage repair
I have a iPhone 6 that has water damage on the circuit board. I have looked over the entire board and cannot find any other corrosion issues. Should I try to clean it with isopro. Alcohol or bring it in for a board level repair?
. Can someone help with identification of this part and a cost to replace it? Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
@cajunphone if you looked over the board you obviously will have to remove all the EMI shileds. You got at least 60% of your boards components covered with those. You cannot do a proper "inspection" without removing those.
I suggest you treat this just like any other water damaged iPhone. The very first thing you want to do is to clean it. Disassemble your phone using this guide. You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Just soaking it will not help. Follow this guide , and even so it was written for a 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone, replace your batteryand reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
The component you are looking at (large IC) is the Murata 339S0228 Wi-Fi Module
iPhone Bild
Anleitung
iPhone Wasserschaden reparieren
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
iPhone 6 Logic Board Bild
Anleitung
iPhone 6 Logic Board ersetzen
Schwierigkeitsgrad:
Mittel
30 minutes - 2 hours
War diese Antwort hilfreich?
Bewertung 2
The component with the most damage is the capacitor that is burnt there. It goes from vcc main to ground. If it is shorted, which is very likely judging by the looks of it, you will have no power to the rest of the phone. I would test it for a short and remove it (WITH a soldering iron) and test for a short to ground again. If it is not shorted anymore, start the phone making sure nothing gets to hot to touch. The chip there is the wifi/ bluetooth chip. If you knock any of the other components off the board though, you may lose wifi and/or bluetooth. Definitely clean and dry the board too.
Bewertung 2
You should definitely clean it with isopropyl alcohol first. Then move on to the harder solutions. I believe that's the power management ic
Bewertung 1
6 Kommentare:
Literally you just posted that 10 seconds before me and I was just going to say the same thing lol
von
Haha. Great minds think alike
von
Great minds? To Funny LOL ;-))
von
Thanks old turkey and imedic and will update on my progress
von
Not very nice, old turkey
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Joe Bab wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 16,379
