Zum Hauptinhalt wechseln
Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
86 Fragen Alle anzeigen
I have to mess with the gear shifter while starting it? Why
I couldn't start my car, after putting it on a battery charger it started. It didn't work with regular jumper cables and vehicle. So I bought a new battery, still didn't start, I mess with the gear $@$* pushing it forward ( it is an automatic ) and holding it their while I try starting it, and it works. But why, why is it doing it how can I fix it and what caused it?
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Will the car start in neutral? If it does then @oldturkey03 is probably right but you may also want to check the shift lock as this can also cause problems when starting
War diese Antwort hilfreich?
Bewertung 2
@marshajo13 when you say pushing it forward, do you mean further into the "P" position? It does sound like a bad or misaligned neutral switch, You'll have to check it out. The switch is located in the central console. It is number 2 in the drawing.
Bewertung 1
Antwort hinzufügen
Marsha Sanchez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 398
