Zum Hauptinhalt wechseln
Battery powered, word-processing keyboard manufactured by NEO Direct, Inc.
How can I attach an extended wired keyboard to my Alphasmart Neo?
I connected an extended keyboard to the USB port of my Alphasmart Neo and it doesn't work. The manufacturer said there isn't a way to do this, but I suspect there may be some way. If you know a way I can do this without using AC power, please describe the steps for me.
I want to be sure that I'm not creating any type of EMF/RF etc. at my extended keyboard by doing this.
Thank you
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Sorry, but the way this device functions is as a keyboard that types out your writing once you plug it into a computer so it won't be able to function with a keyboard itself. i.e. it is a keyboard so you can't attach a keyboard to it.
War diese Antwort hilfreich?
Bewertung 1
Like so many appliances and devices now, it has an actual computer inside it. So technically it is physically capable of supporting an external keyboard, but it would require that software to recognize and run the keyboard be built into the device. From the manufacturer's response, it appears they have not included USB keyboard device driver software, which an external keyboard cannot work without.
So in practice, it would require access to the source code for the software that runs the device, and the ability to either port or write the appropriate software to make the keyboard work, then finally being able to add that code to the device's operating system. There are virtually no manufacturers who would ever let someone outside their company do such a thing, so the net result is no, this will never work.
Bewertung 1
Antwort hinzufügen
Barbara wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 228
