"Battery Is Not Charging" after battery replacement
Earlier today I replaced my RMBP's battery, because it had said "Service Battery" and I could not get more than half an hour of battery life unplugged ("Health" was down to 20-30%).
The new battery seems to be functional; it came with about 35% charge and I used it successfully for a while until it got down to about 10%. Then I plugged it in for a while and let it sleep, but when I came back it was still at about 10%.
Does anyone know what might be the problem? I believe I correctly reset the System Management Controller already (although it is hard to tell).
Here is some hopefully relevant information:
The power adapter indicator light is orange.
Charge Remaining (mAh): 119
Fully Charged: No
Charging: No /* It should be though. */
Full Charge Capacity (mAh): 6762
Cycle Count: 0
Condition: Normal
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 10067
Design Capacity: 6600 mAh
Battery temperature: 34.5°C
Charging with: 0.0 Watts
Battery state: Discharging...
Thanks in advance!
Ist dies eine gute Frage?
Hi, did you ever manage to fix this issue?
von bob jimerson
@bjimerson Not really; I put the original battery back in and turned it in to Apple to fix at a flat rate. Turned out to have bigger problems than just the battery itself.
von Mark Anastos
Good idea, I think I'm gonna do the same.
von bob jimerson
