Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Fingerprint scanner coding fixed?
Hi. Can anyone confirm some recent press stories regarding Apple removing the coding link between the motherboard and the fingerprint scanner? It's always been reported that the home button and motherboard are permanently linked and that the replacement of the home button would render the fingerprint scanner inoperable. Recent stories suggest that (due to consumer pressure?) this link was removed during an IOS update and that home buttons can now changed and the fingerprint recognition features can be now be retained?
Does anyone know definitively whether this is true?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Thanks Tom. Much appreciated.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
For iPhone 5s, iPad Air, the button is not required for the phone to pass update verification. So if you update/reinstall iOS with a dead button, you simply lose Touch ID, that's it.
For any newer devices supporting Apple Pay, the button was required. Updating will fail to proceed and may even kill the device. However Apple finally decided to remove the requirement (they claim that it is simply a mistake, ha ha ha).
In ANY case, the fingerprint recognition CANNOT be restored by DIY repairs. If you break it you lose it. The only exception is the Genius Bar repair works, they have the ability to reprogram a new button during screen replacement.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Bigphilly71 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 74
