Zum Hauptinhalt wechseln
iPod Classic der 6. Generation. Modell A1238 / 80, 120 oder 160 GB Festplatte / schwarze oder silberne Vorderseite aus Metall
904 Fragen Alle anzeigen
Why is my iPod connecting to my docking station but is uncontrollable?
My iPod classic connects to my docking station, charges and also plays, but is completely unresponsive if I try and control it (pause, next song, etc.) via the dock itself and the remote. It's happened with two separate docks, which makes me think it's a problem with the iPod itself. When I plug the iPod in, it doesn't sit straight, but I can't seem to see any blockages inside.
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare:
Ben Perkins does it work properly when disconnected from the docking station? Does the clickwheel function properly?
von
Yeah it works fine, and it works when the data cable is plugged in. Now it completely fails to recognise it's plugged into the docking station
von
Post a good clear images of the port where the iPod plugs into as well as the iPod docking connector itself. Use this guide Bilder zu einer vorhandenen Frage hinzufügen for that. From what you are saying "works when the data cable is plugged in" sounds more of an issue with the dock than the iPod
von
I have updated the question with the photos, thanks for the help!
von
Einen Kommentar hinzufügen
2 Antworten
the docking station might not be a supported accessory for the ipod
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
No, it's always worked before, but I've had this iPod for almost 3 years now
von
the pins in the ipod may be bent, corroded or just dirty
von
What do you recommend I do then?
von
I think you might have to either get a new logic board or solder on a new one. Getting a new one would be a lot easier, but soldering a new one means only buying a little connector for a few bucks.
Bewertung 0
Antwort hinzufügen
Ben Perkins wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 210
