Why is sound coming from only one headphone?
My Monster DNA headphone is giving sound on only one side, whichever side the headphone cable is connected. sound doesnt reach the other side. How to open it to check?
Ist dies eine gute Frage?
martinmassera if both the left and right "speaker" give out sound when connected, then you have a bad (broken ) crossover cable. It connects the two sides. You can check to see if it is as simple as a loose connection that just needs to be resoldered. Or you could build your own external crossover cable. This guide Monster DNA Wire Replacement should get you to the connections. Use a multimeter to see if you have continuity on the cable.
War diese Antwort hilfreich?
@oldturkey03 The guide in your answer is forbidden Mike can you fix it for @vickohh
The same issue, the guide its forbidden.. any other idea?? regards..
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 2,463
