Zum Hauptinhalt wechseln
27" Display mit einer Auflösung von 2560 x 1440 Pixel und Thunderbolt & MagSafe Kabelbefestigungen
Can I modify Thunderbolt display to replace mindisplay with a USB-C?
Hi all,
I have a new Macbook but also a 2012 Thunderbolt display. The Macbook only has a USB-C port and I was wondering if anyone has come across people replacing the Thunderbolt display's Mini Display cable with a USB-C one.
Is this even possible?
Any Mini Display-to-USB-C adaptors were very quickly (and suspiciously...) discontinued shortly after they were released in 2015.
Any advice or info would be much appreciated.
Henry
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
Do be clear here you want to use the Thunderbolt display with your MacBook, correct?
von
At present there is no adapter for the USB-C to Thunderbolt. and i do not believe there is any other way of doing it :(
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Sadly, there is no means to connect a new MacBook which has a USB-C port to a Thunderbolt display presently. Hopefully by the end of next month we might be offered an answer from Apple ;-}
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Just to keep this updated, there is now an adapter available from Apple - https://www.apple.com/uk/shop/product/MM...
von
This is supposed to work, I have not tried it
https://www.nonda.co/products/hub-mini-u...
Bewertung 0
2 Kommentare:
Yep! I thought this hub would do it, sorry nope!
It's only DisplayPort compatible! Not Thunderbolt.
Note the compatibility line at the bottom 'Apple Cinema display only with Mini Display Port' no listing of the newer Thunderbolt display. I know I was hoping too ;-{
von
Antwort hinzufügen
Henry Kirby wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 23
Letzte 30 Tage: 62
Insgesamt: 2,175
