Can I put an iPhone SE into a 5c case?
Can I put an iPhone SE into a 5c case? Love the pink 5c so much, but so much wanted it works like a SE with powerful A9 and 12-mp camera.
Ist dies eine gute Frage?
If you are talking about cases you put over your phone: No, the 5c is slightly bigger. The 5, 5s, and 5se cases are interchangeable though.
If you are talking about the chassis/frame that you screw the logic board and other components on: No, each iphone model uses a unique chassis/frame.
War diese Antwort hilfreich?
Well yes, but actually no.
I managed to do it. But it needs a lot of time, glue and knowledge. It does not work a 100%, things like the Vibration motor does not fit in anymore and smaller imperfections like the camera not aligning are there. But overall it is manageable.
I have a picture of it on Reddit:
No, this will not work. Whilst the 5C is 24.4 x 59.2 x 8.97mm and weighs 132g, the SE measures 123.8 x 58.6 x 7.6mm and hits the scales at 113g. This means that the iPhone SE is slimmer and smaller than the iPhone 5C. Furthermore, the mouting points for parts and screws are also different.
If you really want the SE to look like a 5c you could look around for a case online.
no you cant because they different phone
There are housings out there with different colours etc. You can make your iPhone 5 look like a small iPhone 6S. However, nobody has made a housing to fit an SE to a 5C because it's considered a downgrade.
Your best option is finding some pink housings that are made for the SE:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 14
Insgesamt: 4,820
