Zum Hauptinhalt wechseln
Modelle A1237 oder A1304 / 1,6, 1,8, 1,86, oder 2,13 GHz Core 2 Duo Prozessor
312 Fragen Alle anzeigen
MacBook air hinge question?
i bought a macbook air on ebay that i am repairing and it does not have the little plastic or rubber(not sure which they are)pieces in the hinges that holds the wire in. i was wondering if someone could tell me what they are called and point me in the right direction to buy them.
the model number on the air is a1237
Thanks in advance,
Cody
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Take a look at this repair video to see if you can identify the parts you need: http://www.wonderhowto.com/how-to-repair...
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
good start +
von
right around 7:18 what he refers to as the plastic grey insert. the insert is what i need. Thanks you for your help.
von
APPLE WILL COVER EVERYTHING that is broken even if it's out of warranty!!! I bought my macbook air new in March 2008 and in 2010 my speakers busted and both hinges completely broke. When I mean "broke" the right one was complete detached from the base and the left one finally got detached last week (January 2011). The screen went blank and instead of a laptop I had two hunks of junk - a broken screen and keyboard base.
The apple website is no help and don't call customer service because if you don't have an extended service plan they will not help you. Though the website clearly states that the breaking hinges are a FACTORY DEFECT you can't speak to someone unless you have a warranty.
I made an appointment with my local apple store with their Genius Bar service. I explained what happened. They took it and replaced everything at no cost - The clam shell, the sound board, the hinges, and even a new 1.6 GH process/Logic board. I'll be honest I was almost crying when I saw what they did. Heck, they even cleaned it inside and out so it looks brand new. Apple went above and beyond what was broken. For this I am grateful.
I hope this helps. Go to a major market Apple Store like mine in Los Angeles(not a ma and pa or department store) because they'll give you the best (and free) service.
Good luck
Bewertung 0
Antwort hinzufügen
Cody wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 3,139
