Zum Hauptinhalt wechseln
Das Moto G ist das preisgünstige Smartphone von Motorola. Es bietet für den halben Preis alle Funktionen, die man sich bei einem Smartphone nur wünschen kann. Modellnummern XT1032, XT1033 und XT1036.
Fastboot Erro "Fastboot Reason: Falied to inicialize partition table"
SPEAKING FOLKS Firmness ? STAND WITH A MOTO G 1 GENERATION , I WENT TO UNLOCK The BOOTLOADER AND NOW IT ONLY ON THE Fastboot SCREEN WITH THIS NEXT ERROR ,
" Fastboot Reason: falied to boot partition table " Already Tried Installing A ROM BY Fastboot NOT THE RIGHT OF THIS NEXT ERROR IN ALL
THE COMMAND LINES "failed (remote) " . THE FIRST COMMAND " flash partition mfastboot.exe gpt.bin " IT 'S THE FOLLOWING ERROR ,
''target max-sparse-size: 256MB
sending 'partition' (32 KB)...
OKAY [ 0.024s]
writing 'partition'...
(bootloader) This may take a few seconds, if a
(bootloader) different partition table is being
(bootloader) flashed since we need to backup
(bootloader) and restore a few partitions
(bootloader) Flashing primary GPT image...
(bootloader) Failed to write primary GPT.
(bootloader) Failed to program partition table
FAILED (remote failure)
finished. total time: 5.277s'''
AND IN OTHER LINES OF COMMAND "FAILED (remote failure ) ," JA USED RSD Lite , have USED THE COMMAND " mfastboot oem fb_mode_clear "
BUT WHEN WILL UNLOCK The Bootload THE NEW ERROR SOMEONE I COULD HELP ME ?
I tried to downgrade to 4.4.4 kit kat most still can not install nor a firmeware on bike g and also tried to install the 5.1 version of the same thing.
desulpe the English but I'm from Brazil I'm still learning.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Fiz um vídeo com uma solução para este problema!
Siga o link: https://youtu.be/hmfu6Jx9E1M
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
ja vi esse video n adiantou nada mas meu celular é um moto g7
von
to com mesmo problema meu tbm e um moto g7
von
mesmo problema no meu moto g7 power, depois q eu tentei instalar uma custom rom ele deu hard brick e nao consigo restaurar ele
von
yes this phase me on moto
Bewertung 0
Antwort hinzufügen
Eliseu Oliveira wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 6,611
