Zum Hauptinhalt wechseln
Anleitungen zur Reparatur und zum Zerlegen von Handys aller Hersteller und Service-Anbieter, inklusive Apple iPhone und Samsung Galaxy. Alles, was du brauchst, um dein Handy selbst zu reparieren.
73631 Fragen Alle anzeigen
Vacuum chamber and autoclave
I was doing a little research and I'm still unsure what can I use each of these tools for. From what I read, a vacuum chamber is used for removing air bubbles from a freshly laid LOCA and an autoclave is used to remove air bubbles from OCA.
Please confirm this info and add corrections.
Thank you.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Can you replace autoclave by hot gun
von
Einen Kommentar hinzufügen
1 Antwort
The vacuum chamber(Laminator) is where it presses down on the fresh glass/OCA to evenly seal it. The autoclave pulls any remaining bubbles out. So, yes, you're correct. :)
Source: I refurbish LCD's everyday!
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
This item states that it can also be used to remove Loca bubbles http://www.ebay.co.uk/itm/281906259692
By vacuum chamber I meant a pot-like container, not a laminating machine with the gold plates.
von
That's what I meant, my apologies.
von
Antwort hinzufügen
Ciprian R wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 469
