Zum Hauptinhalt wechseln
Der LB7 Duramax ist ein 32-Ventil-V8-Dieselmotor, der von 2001 bis 2004 produziert wurde.
crank no start: no codes, no fuel at primer, rattle from engine
2002 6.6 lb7 Duramax will not start. Engine was making rattle sound. Sounded almost like a sheet metal vibration but RPM sensitive, coming from low in engine.. There are no codes. Not getting fuel at primer bleed off. no signs of water in fuel. Thanks, Terry
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
These trucks have an injector pump that's driven off the main timing gear. It's in the front of the engine in the valley. So if you heard noise coming from under the hood or front before it stopped running and you have no fuel pressure now while cranking it sounds like your injector pump took a crap. What u can do to verify lack of fuel is get a small rag and wet it with gasoline not diesel and hold it infront of the throttle body. My buddy has a twin turbo duramax and I've helped him pull the motor a few times and he's showed me a few little tips n tricks. A few drops of gas should start it up. U also can check the fuel rail for pressure with a gauge but if u don't have 1 on hand the gas rag can confirm no fuel.
War diese Antwort hilfreich?
Bewertung 0
broken crankshaft...
Bewertung 0
Antwort hinzufügen
Terry wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 26
Insgesamt: 1,774
