Why is my sound distorted as the volume is increased?
why is my sound distorted as my volume is increased?
Ist dies eine gute Frage?
Speakers are a moving part so they can fail. The two things you might encounter is something was spilled into the system (wet or dry) that got into the speaker or is vibrating from it.
I would start off by making sure the system was dusted out and if any screws were found loose tighten them down or if drifting about find were then need to be put back.
Give the system a try then, also try an external speaker which you know are good. Is the sound distorted with them as well?
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 77
1 Kommentar
Are you using the builtin speakers or using an external pair?
von Dan
