Zum Hauptinhalt wechseln
Veröffentlicht am 23. Oktober 2012 mit Core i5 oder Core i7 CPU, optional mit Fusion Drive
208 Fragen Alle anzeigen
Wifi not working, interfering with bluetooth devices
Good Morning. The network wifi on my Mac Mini stopped working suddenly and began to interfere with the keyboard and bluetooth trackpad. You can not find any network and disconnect the trackpad or keyboard when connected. I've tried everything but to no avail. Any suggestion? All USB 3.0 devices were disconnected and performed a reset SMC.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This system uses a combo AirPort card which has both 802.11 WiFi and Bluetooth services. Review this IFIXIT guide: Mac Mini Late 2012 AirPort/Bluetooth Board Replacement. Jump down to Steps 20 through 23 as you can see this one part handles both. Most likely you have a bad board, I would start there.
The part you'll need is: AirPort Extreme/Bluetooth Card - Apple P/N 661-6040
War diese Antwort hilfreich?
Bewertung 3
5 Kommentare:
It's the same board of the Mac Mini Mid 2011? I found the Late 2012 plate with Part Number 661 7030.
von
Which do you have the '11 or the '12 model? The parts are different. The Bluetooth antenna is located in a different locations between them.
von
Mac Mini (Late 2012), 2.5GHz Intel Core i5
von
My mistake ;-{
You are correct you need the 661-7030 part I must have clicked on the wrong link.
von
Thank you Dan.
von
Antwort hinzufügen
Raphael Affonso wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 332
