Zum Hauptinhalt wechseln
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
How do I remove top of machine?
How do I take top off to reattach part that goes down to initiate draining and spinning. The lid has to be closed to initiate this feature. I stupidly overloaded and that piece came loose.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Marsha, If it was the lid switch that came loose check the link below easy to follow instruction/video to show Kenmore washer cabinet removal, 2nd vid. shows lid switch replacement.
https://www.youtube.com/watch?v=vogysB7X...
https://www.youtube.com/watch?v=MFsvLiuT...
War diese Antwort hilfreich?
Bewertung 2
@marshas with the top loader you usually remove the whole cabinet. Take a look on here. There may be a different way for your issue but we need to have the exact model number and maybe a few images of the part that came loose. Use this guide to post images so we can see what you see.
Bewertung 0
Antwort hinzufügen
Marsha wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 10
Letzte 30 Tage: 17
Insgesamt: 10,729
