Zum Hauptinhalt wechseln
27" Display mit einer Auflösung von 2560 x 1440 Pixel und Thunderbolt & MagSafe Kabelbefestigungen
160 Fragen Alle anzeigen
When turned off the fans keeps spinning. Is it normal?
The fans are normally very quiet but when i turn off the computer the fans of the thunderbolt display first starts spinning very fast and after 5 seconds keeps spinning not so fast but keeps running until I power on my computer again. Is it normal?
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
ya it normal.
von
Like Colonel Hogan answered is not normal, and apparently it is a common problem
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Hi,
have you latest Thunderbolt Firmware installed ? Check Mac Software updates. There was an update adressing fan related issues.
Update (01.10.2016)
So, now i found this about the problem.
Seems to be an apple known problem.
https://discussions.apple.com/message/16...
War diese Antwort hilfreich?
Bewertung 1
Hi Colonel Hogan,
Thanks in advance for you answer.
Yes, i've already checked the updates. It is the last version of the firmware (26.2)
It is not normal right? For the thunderbolt display's fans starts when turned off.
Bewertung 0
2 Kommentare:
Have you attached external devices to the TBD ?
von
No, all the ports in the TBD are unused.
von
I realize I'm incredibly late to the party here, but if you've got your MacBook charging even when it's off, the fans will cool the power adapter.
Bewertung -1
2 Kommentare:
Sorry dude, Its a Thunderbolt display not a macbook that is having the problem.
von
yes, that's abundantly clear. in case you're unfamiliar with thunderbolt displays, they have built-in MacBook chargers. when said built-in MacBook charger is plugged into my Mac and charging, it creates heat. the fans inside my Thunderbolt Display turn on to keep the AC/DC conversion circuitry cool, even though the display itself is powered off.
thanks for giving ME a demerit for YOU not knowing what I'm talking about.
von
Antwort hinzufügen
Kojiro Nagai wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 228
