Zum Hauptinhalt wechseln
Umfassende Reparaturinformationen für Spielekonsolen von Sega, einem Unternehmen, das ursprünglich Spielekonsolen entwickelt hat. Seit Januar 2001 konzentriert sich die Firma auf Softwareentwicklung.
168 Fragen Alle anzeigen
Graphic and Sound problems!
HeyHo,
I bought a used Sega Master system 1 Power Base, PAL with antenna cable and the game "Alex Kidd in Shinobi World".
Well, the system works fine but there is a deep buzzing noise at the background. The noise does also change pitch from normal to low, to high....
And the graphics are really messed up. There are huge black transparent scanlines from the bottom to the top of the screen. And at the point where the scanline is, the game changes to black and White... oÔ
I Tried:
  • Another Antenna cable (From NES/Famicom)
    • Nothing Happened. Same Errors.
  • I soldered in a A/V Connector.
    • Same Problems with graphics, but no sound (Allthough I did solder correctly.)
  • I Tried to hook the Game system on a CRT TV (Mine is Flat)
    • Still the same problem...
  • I cleaned up the whole System. Every contact of every connector was cleaned.
    • Of course the error still appears.
  • I Cleaned the Game Module.
    • Same Problem -.-
  • I Opened the system, but every cap, every contact and so on was fine.
I hope you can help me or make a suggestion.
Thanks folks,
Kentsfield
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Wow. That's a little out of my league. Try these places for some extra help. I'm sorry, wish I could help you further.
Genesis A/V Pinout
Genesis Mod Forums
Master System Scart pinout
Good luck!
==Update==
Maybe these will help too.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks, man!
You're Awesome!
With this schematic I can try to fix this problem.
Anybody else got suggestions?
von
It is the capacitors. Common issue. I sell them on ebay. Look up sega master system capacitors
Bewertung 0
Antwort hinzufügen
Kentsfield wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 5,401
