Zum Hauptinhalt wechseln
Modell A1297 Unibody; Anfang 2009, Mitte 2009, Mitte 2010, Anfang 2011 & Ende 2011
544 Fragen Alle anzeigen
tip of the headphones jack stuck inside with superglue
Hi i'm in Peru. I have a macbook pro uni-body. The tip of the headphones got stuck inside in my desperation i took it to a pc service and they tried to take the tip pasting it with another piece with super glue, now is dead. There is no sound from the speakers and no option to switch it in the output from headphones to speakers.
1st i wanna know if its possible to change the piece of the headphones in without changing the main board.
2nd i know that switching the output from headphones to speakers is a software thing cause when i start the computer the booonnggg sound came out from the speakers so there must be an option to change from headphones to speakers via software.
thnx for your help
My email rufiansk8@gmail.com
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
Please keep your questions kid-friendly. I edited the swearing out of your post this time because it's a good question. Next time it will be removed. We love the good questions, but it's gotta be clean for everyone.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
First try hard to remove it using fine pliers if that doesn't work it might be possible to desolder the headphone port from the motherboard and resolder a new one but I don't know where you'd find the jack. This would also be a professional job.
War diese Antwort hilfreich?
Bewertung 2
If it still has plastic on it, you can try lighting a ground wire and put it on the broken piece for a minute or 5 and take it out slowly.
Bewertung 0
Antwort hinzufügen
Marco wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 4,203
