Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost
1624 Fragen Alle anzeigen
Will replace battery indicator will fix sleep sensor problem?
Hi everyone,
I just want to ask if the magnet test( put magnet to make Macbook sleep) not working, will it be the battery indicator/ sleep sensor cable faulty( my battery button indicator still work perfectly) . I just have the problem with Macbook does not enter sleep mode when i closed lit( have ruled all possible solfware issues). Any help would be appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Has the screen been worked on?
von
Yes, it works perfectly, i believe that the issues is the sleep sensor since i has uses the magnet to test it. And the macbook does not sleep when i uses the magnet to fool it so i believe that the problem probably be the sleep sensor. I just don't know if replace it will solve the problem. Thank you for your participation
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Replacing the battery indicator fixed the sleep sensor problems
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
I have looked everywhere to figure out if the replacing the battery indicator will fix it as I have the EXACT same issue. Thanks for letting us know. Looks like I'll have to order that part too.
von
Glad it helps you, the weird things about this cable is that the battery indicator button actually acts independently with the sleep sensor.
von
yeah you are right my battery indicator flex cable are broken during repairing my mac so my mac are not able to either sleep or wake so after repairing i will tell what happened
von
Since the hall effect (sleep sensor) is located on the ribbon cable of the battery indicator board, that will likely fix the issue.
Bewertung 1
5 Kommentare:
Thank you for your response. Do you know if replacing the sleep sensor requiring to disassemble the motherboard. I'm kind of thinking to dissemble the battery and replace it without the need to dissemble the motherboard
von
Yes, you will have to take out the motherboard, since a portion of the cable is under the motherboard. Don't try to take it out without removing the motherboard - I accidentally destroyed one of these thinking I could get away with it . You only need to undo the connectors, and take out 7 or so Torx T6 screws. Then, you just need to remove the battery, and un-do three phillips screws to access the battery light indicator.
von
If the battery indicator light don't light up when you press the button, there is a small chance that there is an issue with the motherboard - replacing the sleep sensor isn't a guaranteed fix.
von
Thank you for your advice and concern. My battery indicator light actually did light up, which makes me a little confusing in concern about whether the cable really broken. I"ll order the part tonight and see if it fix the problem. Thank you for your clarification.
von
And Sam, could the hard drive ribbon cable be the reason why the sleep sensor won't work. I have do some research and found out that some people saying that this cable also responsible for the sleep issue. Is the macbook has 2 sensor for the sleep sensor.
von
Antwort hinzufügen
harryha wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,472
