Zum Hauptinhalt wechseln
A corded, electric, 5 amp spiral saw power tool with a two speed motor by Rotozip. The device comes with a variety of drill bits, sanding and polishing wheels, and a carrying case.
Why is my blade attachment not spinning?
My saw didn't have any problems before I changed the blade, but now the attachment won't spin at all. I don't know what I could've done to break it, help!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Try taking the blade off and attaching it again. If it still doesn't work you might have a faulty attachment. Also, do you at least hear the motor spinning inside? If not, than it might be a more serious problem and you might need to replace the motor itself. Be sure to check out the troubleshooting page for the RotoZip rebel first. Here's the link
RotoZip Rebel REB01 Type 2 Troubleshooting
War diese Antwort hilfreich?
Bewertung 0
You did release the lock I assume after changing the tool bit?
Bewertung 0
Antwort hinzufügen
Lauren Russell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 1,673
